July 13, 2011, 18:09
Donald NicolaiProblem sending pictures
Hi all,
I have put pictures on E-bay numerous times, but for some reason I can't get it to work here. The message says my upload exceeds the allowable size.
Anyone have ideas or suggestions. I'm still trying to find my way around here.
Thanks, Don
July 13, 2011, 19:19
Edward L. Parsons, Jr.Welcome to IHC185 Donald. That means your image file size exceeds 220 kB. You need to reduce the size below 220 kB using an image editing package before you post it.
July 13, 2011, 19:48
Jeff R. MoserI believe if you will make your picture to the smallest size, 640 x 480 your pictures should up load. Jeff
July 13, 2011, 21:51
Larry LamphierHi Don, If you don't have a program to do this send me a note to "larrylamphier@aol.com", and I'll send you a link to one.
July 13, 2011, 22:30
Donald NicolaiThanks everybody,
I'll try some of these things, and if they don't work, I'll get back to you.
Don
July 14, 2011, 09:21
Donald NicolaiThanks Debbie, I appreciate the information.
Don
July 14, 2011, 13:07
David AbbeDon, I use Picasa from Google because;
1. It is "easy as pie" to learn for "Dummies" like me.
2. It is Free.
3. It is very flexible.
July 14, 2011, 17:13
Eric UnseltHi Don -
Like David, I use Picasa. Assuming you can aim the camera, the software allows you to size and edit shots to get results like this.
Having a
light box helps.
July 14, 2011, 19:02
Norman MayberryPicasa is a free download from Google.As Dave says,It's very easy to use.If I can use it,anyone can.Regards.Norm
