April 01, 2017, 00:19
Jeff AinsworthNew Hand Blueing Method
An easy way to blue hands i have tried many ways found this easy
Preperation sand with 1200 wet and dry then5000 using penertrating oil both times then with a small peice of chamois rub hands using an aluminium polish will give them a mirror polish
I then heat up an old base metal case with front bezel removed and 6mm of fine sand in it on a gas stove top on burner center check temperature with infa red thermometer and place hands on bed of fine sand leaving a slight air gap near tip of hand when getting near required temperature hands come up perfect can remove hands quickly to check colour then put back in if need more
April 01, 2017, 00:35
Jeff AinsworthPicture of reblued hans dark patch on end of minute hand is shaddow
April 01, 2017, 00:43
Jeff AinsworthShould have added i polish them on an anvil block with a screwdrive or something in a suitable hole to steady the hands and rinse them in alcohol and dry with cotton bud before bluing
April 07, 2017, 19:50
Theodore J. Brown Sr.Really nice work Jeff!They do look great.
