June 04, 2013, 13:58
Dave TurnerBunn didn't want to run
Here's a first for me. I've spent the last three days trying to figure out why my Bunn 21J wouldn't run after I cleaned it. It ran nice until the leg of the 2nd wheel came up against the screw.
I found a screw in the wrong position!!
I had the screws in reverse order in the cover that holds the winding ratchet wheel on the dial side.!!
Sure feels good to figure that out!
June 04, 2013, 15:59
Jon HartDoh...
Nothing worse than a stray piece of metal between some brass gears
June 04, 2013, 17:11
Jim BielefeldtI hope you found the problem relatively fast. I call self induced problems like that "banging your head into a wall". It never feels good until you stop.
June 04, 2013, 17:23
Dave TurnerJim,
No, it wasn't fast. I had the mainspring barrel out 3 times before I saw it. I kept looking at the balance wheel thinking I had something wrong in that area. Sure is good to finally see what is wrong.
June 04, 2013, 18:24
Mike HodgeI assume the screws were different lengths?
June 04, 2013, 18:43
Dave TurnerYep, they sure are. Next time I'll be more careful to put them back where they came from. I didn't even consider that they might be when I tore it down.
June 04, 2013, 19:13
Patrick WallinWell Dave, now that your fed up with it you can send it to me and I can use it for parts.
June 04, 2013, 19:50
Dave TurnerPatrick,
I'm not quite fed up yet, I've only had it running for about 4 hours now! But so far, she's keeping perfect time.
I put it in this case for now.
June 05, 2013, 13:30
David AbbeThat model Illinois as I remember pointlessly used a long and short screw set (rather than two short screws) to hold on the click wheel retainer plate. If the long screw was installed in the retainer plate screw hole near the middle of the movement (rather than the hole at the edge) then it would stop the watch when the main wheel spoke came around and engaged it.
Really fun experience. When we learn about thie little "tricks" we understand the many colorful names the watchmakers sometimes earned.
