4 foot 992 missing set lever... 974 four foot set lever should fit too.
https://ihc185.infopop.cc/eve/forums/a/tpc/f/1086047761/m/4223934677
December 29, 2012, 20:02
Paul D. Trombley
Hi all,
I managed to buy a running "but not checked for accuracy" 992 that indeed runs like a champ and is correct twice a day if I don't wind it.
It turns out the set lever is gone and I have no other similar movements to scavenge from or to even compare for a replacement part.
Can you point me in the right direction?
December 29, 2012, 21:04
Jon Hart
Here is a 992
December 29, 2012, 22:08
Jared Brinker
Paul-
I may have one, but I won't be able to check until monday or tuesday.
Jared
December 30, 2012, 00:21
With a little filing that 992 lever from the later models would probably work. It is interesting how Hamilton came up with such a simplified Lever set assembly design.
December 31, 2012, 12:32
Paul D. Trombley
It looks like the 974 four foot model uses the same pillar plate and set lever if that is easier to find.
Thanks a mil,
Paul
