The Working Man's Case
May 29, 2004, 17:57
Stephanie O'NeilThe Working Man's Case
You learn as you go. Sounds familiar? So truer words are spoken as I've learned about the working man's case. Here's a bit of information I'd like to share with you.
In the 1500's, time could be viewed through rock crystal cases and pierced lid watches, pre-cursors to and same principle as demi-hunter watches. Unlike demi-hunter watches, a hunter's case must be opened to tell time.
We can trace the meaning of "pair-cases", a protective outer case for use when traveling, as early as the first half of the 17th century. Pair-cases were used to protect a watch from dust as the inner case could not be dustproof since it provided access to the winding and setting key holes in the watch case.
Pair-cases were made of leather and sometimes decoratively tooled. At one point, decorations were so lavish one needed a third case to protect the second, turning full circle. Pair-cases became known as the working man's case and were made of german silver, gun metal, color alloys, or metallic gold colors. Protective cases for ladies were more often made of tortoise shell.
The working man's case served two purposes, to view time and to protect finely engraved precious gold or sterling silver cases from scratching, abrasions, or breakage during the daily "work-a-day" routine, hence the name "working man's case.
Unlike pair-cases, watches were rarely removed from the working man's case since a watch could be wound and sometimes even set while still in the case.
Beauty is certainly not exemplified in working mans cases since they saw their share of physical abuse in their day and as evidenced in my collection. These cases served their purpose though, as they preserved many beautiful watch cases, movements and dials.
At the time of purchase, my very first working man's case
May 29, 2004, 17:59
Stephanie O'Neilhoused a beautifully etched silver 8s case, marked "D.v.d Nykerk on dial. The words "Augusta 21" are printed on the back of brass hinged case.
Stephanie O'Neil
May 29, 2004, 18:02
Stephanie O'NeilI've added only a few to my collection since, as they are seldom seen in today's market.
Here's an inside look at my collection of working man's cases!
A front view of a roman numeraled brass hinged case with glass insert. Holds a 12s.
Stephanie O'Neil
May 29, 2004, 18:04
Stephanie O'NeilAn inside view of case.
Stephanie O'Neil
May 29, 2004, 18:07
Stephanie O'NeilHere's a front view of an ornately decorated brass hinged, and clasped locket watch case. Holds a 0s watch.
Stephanie O'Neil
May 29, 2004, 18:08
Stephanie O'NeilAnother view.
Stephanie O'Neil
May 29, 2004, 18:09
Stephanie O'NeilBack view
Stephanie O'Neil
May 29, 2004, 18:11
Stephanie O'NeilAn aluminum(?) working man's case. Holds an 18S
Stephanie O'Neil
May 29, 2004, 18:12
Stephanie O'NeilBlack metal spring hinged working man's case. Holds 18-20S.
Stephanie O'Neil
May 29, 2004, 18:17
Stephanie O'NeilI'll add to post as my collection grows! Feel free to do the same if you have any working man's cases in your collection or info as well!
Some of the finest pocket watches we see and collect today have been preserved thanks to the working man's case!
Hope you enjoyed the thread!!
Stephanie O'Neil
May 29, 2004, 18:34
John PavlikHere are 2 pictures of the only one I have. It is big and held an English pair case watch complete.. Front cover screws on and it has a thick glass crystal. I believe it was used by miners..
May 29, 2004, 18:38
John Pavlik2nd view...
John Pavlik
May 29, 2004, 21:00
Bruce ByrdI just picked this up today and low and behold I find this thread.. pretty interesting case.. Does anyone have more info on them? Was thinking about putting this on ebay..
Bruce Byrd
May 29, 2004, 21:01
Bruce Byrd2nd pic
Bruce Byrd
May 29, 2004, 22:57
John PavlikBruce,
I think you should buy mine, find one more then you have a collection...
..Mine is made of heavy brass... How about yours.. don't know that much about them....
John
May 29, 2004, 23:45
Bruce Byrdmine is also made of brass with a very thick crystal.. I am gonna stick it on ebay and see what comes of it.. Dont have any info on maker or when they were used.
Bruce Byrd
May 30, 2004, 15:00
Sheila Gilbertsee if this works
Sheila
May 30, 2004, 15:17
Stu GoldsteinSheila how do you open it? Does it have a tab or a slot for your thumbnail? Does it have a latch that holds it closed? Does it have a spring? Thanks!
Stu Goldstein
IHC Member 19
May 30, 2004, 15:20
Stephen L. RussellI have seen a few of these miner cases,I think they were popular in Wales with the coal miners..they are pretty neat.
May 30, 2004, 15:30
Sheila GilbertHi,
It has a hinge, kinda spring like.
It looks and feels like bakelite but it is actually made of lead. I would have guessed a form of plastic but it's lead for sure!
I got it from the site mentioned above. Ruby Lane a few months ago. I don't think I have a picture of it, but if I do I will post it.
I almost purchased the miners case mentioned above too, but got too deep into cases, and display cases I needed to buy it too.
It is neat though. Mine has 1889 on the inside and Ajax too, with a number.
Sheila
May 31, 2004, 12:32
Stephanie O'NeilJohn P., & Bruce B.,
Your "working man's" miners cases are quite unusual. I've not seen any of this type. Thanks for your posts and added information!
Sheila,
Thanks for posting a very neat as well as informative ad! My black metal spring hinged case is different from yours in that the front is "see thru".
Do others have working man's cases to share with us?
I'd like to get some discussion rolling on these cases. Do you think railroad personnel used working man's cases?
I have seen and have a picture of a fireman's case, snagged from the internet.
Stephanie O'Neil
June 01, 2004, 13:32
Sheila GilbertI forgot to mention that in the above link, if you scroll down and enlarge you will see three pictures, and that it also has a case included. I purchased for the insulator and turned out to be a pretty decent watch case too. I don't know what they are called but it also has 2 crystals, so you can see through the front and the back.
Sheila
June 01, 2004, 20:52
Stephanie O'NeilSheila,
I'm a bit confused. It appears each side of the "insulator" cases do not have a crystal but that the inside watch case that would hold a movement,does. Am I correct?
Stephanie O'Neil
June 04, 2004, 12:21
Stephanie O'NeilDo you think "working man's cases" were used by people who worked on railroads?
Stephanie O'Neil
June 15, 2004, 05:11
Sheila GilbertHi,
Sorry, I missed the last two posts.
Mine is only the black case that opens by a spring hinge type of device, and the part inside is a regular watch case, with crystals on both sides. That's the way I received it. In the picture about you can see that the case fits inside of it, and mine is like that.
The insulator is real light, and you just separate it by opening it holding both sides, and open... it's very easy with the spring hinge, no clasp or anything, let it go and it closes by itself.
The case inside is not part of the insulator itself, only the black part is the insulator, and your right, it doesn't have crystals at all.
About the people that work on the railroads using them, I doubt it, since most of the watches were timed and set at the station for a long time, then given to the men for use, I think that an insulator would have been a problem since they hung them up in the offices until they were checked and used, and I believe later when they carried them, themselves, they didn't keep them in anything for the sake of convience. So far, that is what I have read.
It sounds reasonable to me, so I figure it's probably true.
BUT.. I did also read (once) that they DID use them, because of the magnatism issue on trains, so who knows! I'm sure that someone here knows the answer to that one. Sure hope someone answers this one for us.
I'm beginning to think that you can't be interested in watches without thinking of cases and things like these too, at least for me, they are part of the entire package.
I just hope I can learn the differences in all of them, so that I will know which case go with what watch, while searching for the "just right" protector.
Yours are really nice.
ps love the background too!
Sheila
June 15, 2004, 20:38
Tom HuberI just picked up two of the black bakelite cases last week at our chapter mart--one 16S and the other 12S. Both in like new condition. Found them in a box marked anything for $1.00 After seeing what they have sold for guess I scored in a meager way.
June 16, 2004, 12:47
You said "the part inside is a regular watch case, with crystals on both sides" FYI watch case is called an exhibition or salesmans case. Thanks for your input!
Glad you enjoyed background of pics as they are part of a vintage postcard collection I own! Will be putting them to good use for future backdrop in showing watches!
What do others think?
Other areas of train or locomotive where a working man's case may have been used?
Tom H.,
Good find!
Stephanie O'Neil
June 16, 2004, 12:52
P. S. Those postcards you see are all of the New Orleans area. Several are views of Canal St. from the late 1800's and early 1900's. One is a view of the wonderful courtyards from the 30's or 40's.
Stephanie O'Neil
June 17, 2004, 13:02
Sheila GilbertStephanie, Thanks you, I thought that is what it was, I had read about the salesman's cases in some posts here and other places but was not sure.
Your post cards are great, and using them as a backdrop is a wonderful idea. I really like the effect on the view too.
Sheila
