January 29, 2009, 23:40
Bruce CunhaCerium Oxide Glass Polish
Hi
The facility I work at just closed our eyeglass manufacturing shop. One of the items that was being discarded was 40 pounds of Cerium Oxide glass polishing compound. This is a powder that is used for final eye glass polishing. It should be a good substance for polishing bezel's.
If anyone could use some, let me know bruce.cunha@charter.net
January 29, 2009, 23:49
Mary Ann ScottWilliam White is making pocket watch crystals. Maybe he might be interested.
January 30, 2009, 17:39
David AbbeYESSS! How about breaking it up in 1 pound Baggies!
January 30, 2009, 17:58
Tom BrownBruce
I also emailed you asking about how to get some, just in case I came through as spam.
Thanks
January 30, 2009, 19:19
Edward KitnerBruce I e-mailed you also.
January 30, 2009, 20:11
William D. WhiteHello Bruce & Mary Anne,
To tell you the truth, I've got about 4 lbs left from a 5 lb bag I bought 10 years ago! Others here will be interested though and it is no doubt a very fine grade. I would not recommend polishing bezels with CeO2. It is not not a suitable metal polish.
William
January 30, 2009, 20:23
Enzo Liguorihi all,
can you pls tell the process how to polish glass with this compound?
tnks rgds
Enzo
January 30, 2009, 22:37
Tom BrownEnzio
I have yet to try it but this link has a little info on it.
http://www.facetingmachines.com/polishing_glass.shtmlTom
January 30, 2009, 23:29
Jerry KingI'll take a pound Bruce....
January 30, 2009, 23:48
Bruce CunhaMary
Old age setting in. I was looking at my watch bezel when I was typing. I meant the compound is for polishing the crystal.
For those that are interested. Send me your address and I will send out a USPS prepaid box full for the shipping cost of $4.95. I got it for free so only need to cover the shipping.
The web that Tom listed is what I used to polish scratches in my side window on my MG. It worked well on fine scratches. For a watch crystal, I would think you could hand polish them.
I looked on the container and it did not list if this is 90%, 95% or 99%. It was used for final polish of eye glasses, so it should be correct for glass crystals.
January 31, 2009, 00:56
William D. WhiteBruce,
The best way to remove surface scratches from glass crystals is to get very dense felt or a piece of leather, maybe about a foot square, and fix it securely to a flat surface. Mix a thick slurry from the Cerium Oxide and water and put a generous amount in the middle of your work area. Start working the crystal around and unless it's very thin, don't be afraid to exert good pressure and speed...this process can take a little while. The slurry will begin to dry out after a short while at which time you should give it just enough mist to keep it from drying. If you get it too wet, it won't work well. Cerium Oxide works both mechanically and chemically and when you get the water balance just right, you'll notice a lot of drag and heat. CeO2 is magical stuff but remember that it's a final polish so don't expect miracles when it comes to glass with deep scratches.
Good Luck.
William
June 23, 2012, 21:28
Dave TurnerBruce,
Got any of that cerium oxide left after 4 years?
I've got an old crystal I'd like to try and bring back to life.
June 23, 2012, 21:30
Claude GriffithI will take a pound also if any is left
June 24, 2012, 13:17
Richard M. JonesI could use a pound or 1/2 pound also.
June 24, 2012, 13:32
Mike LaForestBruce asked me to mention he still has few pounds left as of Sunday afternoon.
June 24, 2012, 13:57
Jim BielefeldtI really could use some, I recently got a load of crystals with label dots under some of the labels.
June 24, 2012, 15:56
Roger StephensI too,could use some.I have lots of crystals with minor scratches etc. Regards Roger
June 24, 2012, 23:41
Douglas D. WeaverI'd like 1/2 pound if possible.
Doug
June 26, 2012, 08:55
Claude GriffithIf it helps someone get some I will take a 1/2 lb rather than 1lb. Since the well is drying up might as well take a little less.
June 26, 2012, 14:24
Larry BuchanI would like half a pound to if possible.
