Unusual Illinois Dial
https://ihc185.infopop.cc/eve/forums/a/tpc/f/1086047761/m/310109311
June 25, 2009, 01:55
Mike Hodge
http://cgi.ebay.com/ws/eBayISA...AIT&salenotsupported
Here is a dial I haven't seen before. Anybody have comments?
June 25, 2009, 06:47
Steve Middlesworth
Mike,
It's an early "Red Ball" dial normally found on the lower grade movements of the earliar period from about 1910 to 1915 or so and would not have come on this 1925 Sangamo, It is a 16 size dial on a 17 size watch.
Steve
June 25, 2009, 16:17
Mike Hodge
Thanks Steve, I suppose 17 size dials are scarce as hen's teeth.
June 25, 2009, 17:42
Steve Middlesworth
Mike,
Difficult to find in respectable condition unless you buy another watch with one on it.
Steve
June 25, 2009, 21:39
Eric Unselt
Steve, I've got a couple of these Red Ball dials on 16s watches; would the feet line up for a 17s movement?
June 25, 2009, 22:41
Steve Middlesworth
Eric,
They most certainly will. The auction above is an example of that and you see that in many instances on ebay listings. If you look at the above listed auction with one of the photos of the bezel off, you can see part of the pillar plate exposed just inside the ring of the frame. What you see there is the difference between a 16 size dial and what would be covered by a 17 size dial.
Read this thread "Click"for a good explanation
Steve
