Elgin 3F Bridge Close-up Details G#280, 270 &156
https://ihc185.infopop.cc/eve/forums/a/tpc/f/1086047761/m/2991046422
January 07, 2007, 16:46
Sean Plummer
G#270 Balance and Roller- Nice quality steel polished SINGLE roller table and D-type ruby roller jewel.
January 07, 2007, 16:50
Sean Plummer
G#270 Top plate train side- The finishing is nickel with spotting type finish on almost all surfaces. Note: Although the spotting is impressive it seems that the combo, spotting and snailing of the G#280/BWR is more dramatic visually.
January 07, 2007, 16:52
Sean Plummer
G#270 Top plate dial side- Excellent detail here with spotting covering the entire surface, also the setting components are Highly polished. Note: Much better than the G#280/BWR grade.
January 07, 2007, 16:54
Sean Plummer
G#270 Screw Heads- The polished screw heads are Above average Beveled Head type, and found on only highest nickel Elgin grades.
January 07, 2007, 17:03
Sean Plummer
Here is the assembled 21 Jewel Grade #270- This movement is in pretty nice overall condition.
In summary, this is a High Grade 21 jewel Elgin movement, featuring many of the higher quality finishing details offered by Elgin. This movement seems to be finished to a higher degree than the G#280/BWR.
On the other hand, this G#270 is only a SINGLE roller escape design. I believe the 17 Jewel G#280/BWR would be a better overall operational watch due to it's better escapement design.
