18s Hamilton "Thor" 17J Info please
July 19, 2019, 22:33
Harry J. Hyaduck Sr.18s Hamilton "Thor" 17J Info please
Any info of the 18s Hamilton "Thor" would be greatly appreciated. I know they are private label. From my own research I have found out that they have a unique demaskeen pattern and are signed "Thor" and have a dial signed by Hamilton. There are not many pictures but all the ones I have found both hunting and open face have Monty dials. I have a 926 and a 927. They both have the same unique demaskeen pattern. The 926 I purchased complete. The 927 was a movement only. I have put a Monty dial on it because all the hunters I can find pictures of have Monty dials on them. I must admit a Monty dial does not look right on a hunter movement if you asked me. I put it in a hunter case. So I am just wondering if anyone has ever seen a Hamilton Thor that did not have a Monty dial on it.
Harry
July 19, 2019, 22:56
Roger StephensCan't help on this,but sure would like to see it.
The ones you saw with monty dials, were they marked
the sane as the movement? Double sunk
I am like you a strange combination.
Roger
July 19, 2019, 23:13
Harry J. Hyaduck Sr.Hi Roger, I will take some pictures tomorrow and post them here.
I have seen Hamilton PL's put just a PL dial on their movements, I have seen Hamilton inscribe just the movement and I have seen Hamilton inscribe both the movement and dial.
A monty dials were not marked like the movement. They were ordinary Hamilton Monty dials. One of a very few post I found made reference to the "Thor " movements having Monty dials marked in the typical Hamilton manner. In my case Hamilton in script.
Harry
July 20, 2019, 00:23
Bila WirriganwaltersHello Harry
My Dad has a book which mentions the 18 size Hamilton "Thor" Grade 926 movements, I think it is by Roy Ehrhardt & Bill Meggers. The one mentioned was sold under the name of "L. Manheimer & Bros New York", circa 1912, does not mention what type of dial though, maybe a Private Label for them. Hope this helps a little?
Erin
July 20, 2019, 00:47
Harry J. Hyaduck Sr.Hi Erin,
Thank you very much for the information. That matches what I have read that "L. Manheimer & Bros. of New York" jewelers. I have a few of those books but I must not have the correct ones because I have not sen anything on them. The post I found was about the 16s version but everything correlates to the 18s version that I can find out. Every picture I found of the 16s and 18s all had the Monty dial. I would much prefer the Roman Numeral dial but I want to put it back as close to authentic as I can and I did not see any with a RN dial.
I hope Bila is well or at least improving. Tell Bila I said hi!
Harry
July 20, 2019, 01:05
Harry J. Hyaduck Sr.Roger here are a few pictures of the 926 Thor and the 927 Thor. The 926 Thor is just how I got it I have not cleaned it up yet. The 927 I purchased was sold as a parts movement. It was missing the hour wheel, the case screws, the dust ring, the dial, hands and case. But it ran which was my hope when I bought it. The first three pictures will be the 926 and the last three will be the 927.
Harry
July 20, 2019, 01:06
Harry J. Hyaduck Sr.926-1
July 20, 2019, 01:07
Harry J. Hyaduck Sr.926-2
Harry J. Hyaduck Sr.926-3
July 20, 2019, 01:08
Harry J. Hyaduck Sr.927-1
Harry J. Hyaduck Sr.927-2
July 20, 2019, 01:09
Harry J. Hyaduck Sr.927-3
July 20, 2019, 12:52
Roger StephensNice, resembles the 940 with that tire track.
One of my favorites.
Roger
July 20, 2019, 13:12
The 16s Thor pattern looks similar to the first pattern used on the 992. So I am thinking that the jeweler ordered all the Thor's to look similar to their 16s and 18s 21J 940 and 992.
Harry
July 21, 2019, 11:05
Theodore J. Brown Sr.Thanks for showing those sharp looking unusual Hamiltons Harry! I have heard of them but this is the first time seeing one. Probably a little on the rare side.
July 21, 2019, 13:55
Nathan MooreHarry -
Halligan documentation confirms the “Thor” movements were produced with a special damaskeening pattern for L. Manheimer & Co.
While these metrics may not be comprehensive, the notes indicate the following production recorded for each grade:
974P: 300 Recorded as “Thor”
974L: 50 Recorded as “Thor”
975P: 290 Recorded as “Thor”
926: 40 Changed to “Thor” (Gilt Letters but not gilt trimmings) [First Grade 926 “Thor” Watches 968,001 - Sold in 1918]
927: 40 Changed to “Thor” (Gilt Letters but not gilt trimmings)
The "Thor" pattern is also mentioned in a short list of custom private label damaskeening designs.
July 21, 2019, 19:02
Harry J. Hyaduck Sr.You are welcome Ted!
Harry
July 21, 2019, 19:07
Harry J. Hyaduck Sr.Thank you for the additional information Nathan.So if I am understanding this correctly that both the 926 and 927 both had a total run of 40 each? (unless some new information surfaces which happens from time to time). I figured more than that were produced. I have seen three Thor 926's (including mine) but this is the only 927 I have seen.
Harry
July 22, 2019, 08:44
Nathan MooreHarry - I would not consider these comprehensive or finalized production numbers. They are simply the counts specifically recorded as such in Hamilton records.
A few conclusions can be drawn with this information:
1. The "Thor" private label was produced by Hamilton for L. Manheimer & Co. (L. Manheimer & Bros.)
2. The "Thor" movements featured a custom damaskeening pattern, significant enough to appear by name in a small list of special patterns within the factory records.
3. The “Thor” name was applied to a variety of 16s and 18s grades.
4. The production was relatively low but significant enough for documentation in summaries.
July 22, 2019, 17:36
Harry J. Hyaduck Sr.Thank you Nathan!
Harry
