February 17, 2019, 15:23
Timothy WhiteBlindman Montgomery
I have just come across the term "Blindman Montgomery dial."  Is this the same as a "Montgomery dial?"  What is the significance of the Blindman terminology?
Thanks
Tim
February 17, 2019, 17:58
Claude GriffithThe only thing I could think of is a term referring to large bold numbers where the earlier Montgomery dials had main number that were less bold.  The numbers became bolder, fatter, larger or whatever term you want to use and saying they were blindman probably referred to the fact you could have poor vision and still see the main numbers.
February 17, 2019, 19:48
Harry J. Hyaduck Sr.They probably came up with the name because the numbers are so large that even a blindman could see them. IMHO. You don't see a Monty6 Blindman that often.
Harry
February 18, 2019, 08:42
Nathan MooreTimothy - As Claude mentioned, the "Blind Man" terminology refers to a dial featuring larger and heavy numerals.
For visual reference and comparison, here is a dial page from the 1920 Hamilton Material List. The first dial (#576) is described as
"Extra heavy Arabic or "Blind Mans"" while the dial below (#436) is simply described as "
Heavy Arabic."
And if you want a truly uncommon Montgomery dial, find a watch fitted with dial #585.February 18, 2019, 09:51
Claude GriffithIf you look at the two dials to the left 576, 436 and compare them to 530 and 531 you see the difference in the look. 576 and 436 most would call "blind man's dial". 581A most would call 'blind man's Montgomery Canadian (or 24hr))and the font on 436 is nearly identical to 581A.  The true "blind man's dial had raised spots with a locator for 12 which has more than one raised spots and some have the same from 3/6/9 and called "braille dial". Some have 3 spots for 12 and two for 3/6/9 and one for the other numbers.
February 18, 2019, 15:55
Timothy WhiteAll great information.  Thanks for all the responses.  I see that none of the dials have "Railway Special" written under Hamilton. When did they start making the watches with the railway special written on the face?
Additionally I am looking for a 992B Railway Special with a Monte dial.  If anyone has one they want to sell please let me know.  There is a long story attached to my need but the short story is that that particular watch has sentimental value to me.
Thanks again to all.
Tim
February 18, 2019, 19:05
Claude Griffithdepending on the year a good 992B dial might be tough to come by because the later ones are melamine and age crack badly.
February 19, 2019, 18:32
Roger StephensTimothy, the dials signed HAMILTON RAILWAY SPECIAL
appeared in 1940 along with the all new 992B. But
not all movements had these dials. Some had dials
with HAMILTON in block not the script style of
earlier movements.
Hope this helps.
Roger
February 19, 2019, 21:31
Harry J. Hyaduck Sr.Tim I think the dial you are referring to is the Hamilton 522 or 537 dials listed on this site under
Hamilton 992, 992b, and the 992E dials. I don't know if you can look at that section or not without becoming a member.
February 19, 2019, 22:49
Timothy WhiteThanks for all the great information.
Tim
February 20, 2019, 00:29
Tom DunnTim contacted me about wanting to buy a 992B with a Montgomery dial, I'm the one that used the term 'blindman montgomery" when describing the watch to him. As stated above this term describes the extra bold arabic numerals on this dial.
So here's the dial in question: As Harry stated it is indeed a #522 dial and not a bad looking example.
Also, as Roger posted some dials like this 522 appeared on early 992Bs as well, this one is a 1941 example and has the correct Model 11 case.
Tim, I also suggest you join this group as there is a wealth of information available here and the membership dues will pay for themselves many times over.
 February 20, 2019, 14:22
Wesley Clay WilkinsTim, I have several 992B's with Monty dials.
March 09, 2019, 13:50
Steve BrownNew to this forum. How do you send a PM? Thanks!
March 09, 2019, 16:55
Tom DunnSteve, you cannot send a PM on this site. You'll need to just reply here or click on the members name
you want to get hold of and should see an email addreess.
