September 20, 2007, 10:53
Ethan LipsigHow Could This Have Happened, and What Can Be Done?
Last night, I wound and set a very nice 14k 12 size Illinois Model 1 Extra Thin. When I checked the time a little later, to my horror I found that the "open square" end of what had been the original and perfect hour hand had somehow broken off. I have attached a pre-catastrophe photo of this watch so that you can see how it used to look. The hour hand now ends where the open square end began; the open square end now is lying like a dead animal at the bottom of the dial.
Have any of you experienced such spontaneous hand disintegration? What causes it? Is there a way to prevent it?
Do any of you have a replacement hour hand or an appropriate set of replacement hands for this watch that you would sell to me, or do you know where I could buy them?
Is there any decent way of repairing the broken hand?
September 20, 2007, 11:07
David AbbeMany PROFESSIONAL Jewelers have a micro-laser welder that is fully capable of fixing the hand as you described.
My Jeweler here would probably add a very thin reinforcement behind the broken spot during the repair to reduce the likelyhood of a "repeat performance".
That depends on what the hand is made of, gold, plkated brass, plated steel, etc.
September 20, 2007, 11:24
Ethan LipsigThanks, David. I will look into this alternative.
September 20, 2007, 12:05
Mark CrossSounds to me like one hand hung up on the other and it snapped at it's weakest point.
Leon Harris of our chapter is a wizard at laser welding, if you're needing a source.
Regards! Mark
September 20, 2007, 12:41
Dr. Debbie Irvine
Ethan,
One of our members, Leon Harris may be able to help you.
Leon is a fourth generation jeweler and watchmaker who does remarkable work.
Here is a sample...
Grandpa's Watch, A Restoration Project
You may contact Leon at HarrisLJ@msn.com or phone 931-261-0543
Dr. Debbie
September 20, 2007, 13:22
Mark CrossThanks for providing Leon's email address, Dr. Debbie. I didn't have it in hand when I told him about Leon's laser skills in my post.
Regards! Mark
