April 07, 2006, 09:07
Mark CrossA quick Hamilton 974 info question
I own a Hampton 974P watch, and have found two different 'build' dates on the movement. One location I looked in said it was built in 1932. In the REALLY small type print of the Hamilton records we have linked from here, I THINK I'm seeing a build date of 1927!
Would someone with a good record please give me the correct information on my watch build date?
Serial number 2455007.
Thank you for your time!
Regards! Mark
April 07, 2006, 11:53
Mark CrossThank you, Lindell, but the Gelsen list IS one of the areas I mentioned in my post above, and the one I THOUGHT I could make out the 1927 date. I couldn't make out the information clearly on my monitor, and the print I tried didn't clear things up at all.
The other source was the Shugart book. Guesstimate material? Probably so.
You've provided what I needed, and I thank you very much, sir!!
Regards! Mark
April 07, 2006, 12:20
Mark CrossHoly smokes, Lindell!
Yep, that's the date I saw too. (I posted 1932, didn't I? Well, I was close just using memory.
) Wow. That's a bit different than the actual Hamilton 1927 records date, isn't it?
Thanks again!
Regards! Mark
