January 12, 2010, 11:35
Melvin SiedmanBergeon Tool
Can any body help with the use of the attached tBergeon Tool 's use Holes are marked 3 to 30
January 12, 2010, 20:13
David AbbeWheel Pivot Diameter Gauge?
January 13, 2010, 14:51
Melvin SiedmanGood thoughts.
Does anybody have an old catologue?
Perhaps with a discription
January 13, 2010, 15:59
Edward L. Parsons, Jr.The size of the holes increases with the numbers, which lets out wire gauge.
The diameter of the wire increases with lower gauge number.
January 13, 2010, 17:58
Gerald ZimmermannPerhaps you can detemine the size of one hole with a small drill bit. I guess the numbers indicate the diameter in hundredths of a milimeter
Gerald
