September 13, 2015, 14:29
Charles McPherrenIllinois watch info
I need info about Illinois watch 19 Jewel Hunting case movement #3772723. Thanks for any info.
September 13, 2015, 15:51
Kevin HoffmanHi , I use pocket watch data-base to look up most movements, it is lacking on yours ! , to recap it says you have a 16 size 19 jewel hunting movement ,made around 1920 if you post a picture i could probably figure out the model and grade. Was this the info you were looking for?
September 13, 2015, 16:20
David AbbeYour watch is a Model 6, 19J movement, adjusted for Temperature and 3 positions. Grade 306. It should have a Double Sunk Glass-Enamel dial. Total production of 3,010 movements. Your s/n was manufactured as part of a 500 piece run in 1920. A very good, tasteful "carry" piece for the Gentleman of the 1920's.
September 13, 2015, 17:38
Charles McPherrenThanks to all for the information.
