My last catch ... an 1884 Waltham
https://ihc185.infopop.cc/eve/forums/a/tpc/f/1086047761/m/2171029233
January 29, 2009, 06:20
Mario Pagani
This big watch arrived this morning, almost 4 oz. of English silver & movement. As far as I know, it should be a model 1877, 7 jewels, size 18, steel balance wheel, Home or St. Martyn Square. The case is hallmarked Birmingham 1883 by the ubiquitous Alfred Bedford. Have I gathered right informations ? Could you kindly add something, if so ?
Thanks a lot
January 29, 2009, 07:47
William D. White
Mario,
Looks like the original case so it sounds like it was made for the British market. Others who know much more than I do will likely chime in with better information. Nice old Waltham though!
William
info@whitescrystals.com
January 29, 2009, 13:12
Mario, You can look up the Waltham records at;
http://www.nawcc-info.org/WalthamDB/LookupSN.asp
For your 2398831 serial number the report is below. It is #30 of 1200 Pc's made in that run. This is a Home model which is an export movement;
Start: 4/1/1884 End: 6/30/1884
First: 2398801 Last: 2401000
Model: 1877 Name: Home
Material: U Grade: Home, MartynSq.
Size: 18 Size: 18
Plate: FP Plate: NL
Jewelling: Plain Jewels: 7
Balance: Steel Bal. Bal: 0
Style: KW Style:
NL
January 29, 2009, 13:30
Mario Pagani
David, a pleasure reading you. There was a "Complete price guide" question lingering below it, as you might imagine. If I could assume that this is a Martyn Square, and, of course it has been exported, it would really be a bargain, I paid out about 35 USD for this watch...
Incidentally, I'm trying to have it work, and some steps have been done, now runs, not continously, but run. When arrived was dead stuck.
Thanks for your answer from your friend down in Italy
PS: I am studying a very early Baume
