Q: ID'ing a watch [A: American Watch Co.]
November 28, 2013, 17:57
Jerry DriscollQ: ID'ing a watch [A: American Watch Co.]
Newbee here:
I'm trying to get some info on a watch and to educate myself along the way. The watch in question is a size 18 in a white metal case. The case has a provision for a lever set watch, but this movement is stem set. The crystal unscrews nicely, and the porcelin face is unsunk and has a very small chip at the 9 o'clock position. The face is marked "A.W. Co."
The fob or chain bail is missing from the stem housing. The stem pulls out easily allowing the movement to swing upward with only slight pressure. The second hand was working well, however when I turned it over to photo the back, it fell out. Thankfully it wasn't lost, and it went right back into its hole, but now it doesn't rotate. The interior of the case has a small shield with the letters "AW" over "Co". There is also the number "7777" and a small jewelers mark "134+".
The back of the movement is engraved "STERLING" in plain block letters and under that is engraved "WALTHAM, MASS." in fancy block letters. Small block letters indicate "SAFETY PINION" and there is a serial number "2967482". The rest of the back is plain, except for fancy engraving behind the adjustment indicator.
I don't think the watch is a brand name Waltham, but rather it was just made in Waltham, MA. I can't seem to find a company named "A.W. Co" anywhere so I'm stumped. The watch runs well, although I am reluctant to run it as I don't know when it was last serviced and I don't want to do damage to un-lubed surfaces. I did spray it real well inside and out with WD-40 to keep it from rusting.
I'll try to post the pic's, but I'm having a lot of trouble with the sizing. As a side bar, can anyone tell me how to resize in Picasa?
I sure hope that ya'll can get me started off in the right direction with this. I don't think this watch is particularly valuable, but I would like to fix it up for an everyday carrier.
By the way, I was just kidding, about the WD-40, I didn't really do that, I just threw that in there to keep everybody awake.
November 28, 2013, 18:07
Jerry Driscollhere is one
November 28, 2013, 18:08
Jerry Driscollhere is another
November 28, 2013, 18:09
Jerry DriscollIn the first photo, the crystal is removed for clarity
November 28, 2013, 18:22
Tom BruntonA.W.Co. is American Watch Company,Waltham Mass ,- Waltham for sure, and on page 119 in the 2012
Fat Book (available from IHC185) in the Waltham section are 4 Sterling model 18 size watches listed from 7-15 jewels
November 28, 2013, 19:19
Peter Kaszubskimodel 1883 7 jewel watch from Waltham aka as AWC.
November 28, 2013, 22:27
Robert LetourneauJerry, if you're trying to resize photos in 'picassa', the easiest way to do it is simple. As you're glaring at the photo in picassa, look down below where it says, 'export', just click. You'll see a dialog box which comes up. Right in the middle of that dialog box you'll see a number, such as 800 or something like that(way too large to post), with pixels printed next to it...just resize to 480 more or less, and you'll be good to go, believe me the picture will be quite clear. Rename the file you just resized and you're ready to post.
November 28, 2013, 23:06
Andy SchwartzGrade: Sterling
Srerling
Movement Serial Number:2967482
Estimated Production Year: 1886
Run Quantity: 2500
Jewels: 7j
Movement Finish: Unknown
Model: 1883
Movement Setting: Pendant
Plate: Full Plate
Adjusted: No
Railroad Grade: No
Notes: Srerling
November 29, 2013, 01:30
Jerry DriscollSo I can do it myself in the future: How do you determine its "Sterling"? Then once there how do you know 7j?
I looked up the cited reference and it shows for the 2 stem wind entries:
Sterling, 7-11J M#1877, M#1879
Sterling, 11-15J M#1883
I'm don't really undertand. It would seem that the first entry would indicate that the M#1877 was 7J and the M#1879 was 11J. But the second entry would indicate that the M#1883 varied with some watches being 11J and some being 15J.
I'm as confused as a goat on astroturf.
Just to clarify, my book is No. 26 the 2006 edition of "Complete Price Guide to Watches" but the page 119 reference seems to hold true.
November 29, 2013, 11:33
David AbbeJerry, We all joined together in IHC185 to share our sum experience and reference libraries to research, identify, clarify and learn about variants such as your watch in question.
That said, using the "big book" to find your American Watch Co., Waltham, Model 1883, 7 Jewel, "Sterling" puts you in the "astroturf" pasture without hesitation.
The "Big book does
NOT list such a watch at all. The closest one in the book would be the "Sterling 11-15J M#1883" listed.
The "big book" has many, many omissions, and is truly best used as a relative value reference guide only.
i.e. your watch is somewhat unusual for that description, but it IS a Waltham model 1883, 7 jewel Pocket watch named "Sterling" on the Barrel Cover plate. To answer your questions about "how" we get here with your watch, experience with these models shows:
1. The basic 7 jewels REQUIRED are including the Balance wheel (2 hole Jewels and 2 Cap Jewels) pivot jeweling, the escapement Bar Jeweling (2) and the Roller Jewel mounted to the Roller (1) assembled to the balance wheel staff. Waltham ALWAYS put those 7 jewels in this model, Minimum, but they are not in view as they are hidden between the movement plates.
2. If there are ANY MORE jewels used for the movement wheel train, they will be clearly visible on the main back plate of the watch you see when the movement is in the open.
(Below illustration shows a 17 Jewel with plate mounted jewels on left and another 7J model 1883 Export model on the right.) 3. The model (year of first design) designation is evident from the design of the Balance cock/Barrel cover configuration which has a deep notched cover and a "toe" on the balance cock that conforms to that notch. The 1883 has the deepest of that series . . . this IS an 1883,
For value purposes, I would compare it with a similar export production model such as the "Sterling 11-15J M#1883" listed.
These 7 Jewel model 1883 movements were fairly robust. If this one can be restored, it would make a nice, albeit "heavy" carry piece. It is virtually unadjusted, so there could be a few minutes a day time variations with temperature and positions.
November 29, 2013, 12:30
Andy SchwartzI have learned less than David has forgotten. What a lesson from the meistro!
November 29, 2013, 12:38
Dave TurnerAmen Andy,
Or, in other words, He's forgot more than I'll ever know.
Dave Turner
November 29, 2013, 13:26
Eric UnseltWelcome, Jerry. Please consider joining us, using
this link.The
Waltham Model '83 is one my personal favorites, simply because the Waltham design engineers made such an incredible array of plate patterns and styles - from your gilt style, to frosted, two-tone, gilded, and straight nickel:
November 29, 2013, 14:53
Jerry DriscollTnx big time to ya'll for the help. What was throwing me was to try to find "Sterling" as a manufacturer rather than a model name. Also, I was trying to take the book to literal. The advice:
The "Big book does NOT list such a watch at all. The closest one in the book would be the "Sterling 11-15J M#1883" listed.
is golden! I will definitely remember that.
