Hairspring Rust
https://ihc185.infopop.cc/eve/forums/a/tpc/f/1086047761/m/1873964067
April 05, 2011, 11:01
Christopher Darwin
Hairspring Rust
I have an Elgin Model 8 B.W. Raymond (18s 19j 3/4 plate) that keeps excellent to railroad grade time. A watchmaker looked at it the other day and said it's off beat (ticks and tocks are slightly syncopated) and there are spots of rust on the hairspring.
Short of taking the watch apart, which I hate to do because it performs so well, is there anything I can do to prevent further degredation of the hairspring?
April 05, 2011, 11:26
John W. Clark
IMHO small spots of rust should not make it impossible to put a watch in beat. The problem with the rust comes when you try to regulate the watch. It usually makes it virtually impossible.
regaards, John
April 05, 2011, 12:05
Roger J. Nolfe
OK Chris...This is the third time I'm trying to reply to your post. I guess I should read what we are dealing with before I type a reply. Smile
You can easily check to see if your watch is in beat without taking anything apart. You might need a magnifier or loupe. Let the watch run all the way down. Observe the pallet arm and find the banking pins. If the arm is centered or nearly centered between the banking pins your watch is in beat.
April 05, 2011, 14:08
Christopher, If it is running well now, please leave it alone. When it begins to deviate on time accuracy, have it serviced by someone trustworthy like our very own Chris Abell.
A watchmaker telling you it is "off beat" is as meaningless as a doctor telling you you have a "grey spot" on your x-ray".
April 05, 2011, 19:38
Roger J. Nolfe
Christopher,
I agree with David to leave it alone if it is running well. I gave you a way to check for proper beat so you could see for yourself and maybe that would help alleviate any concern you may have. It also tells you something about the watchmaker if it is OK when you take a look.
