How do I set the time on Columbus Watch 18s
https://ihc185.infopop.cc/eve/forums/a/tpc/f/1086047761/m/1511007213
June 05, 2008, 22:17
Ernie Loga
I have an 18s Columbus grade 95. It runs great. I took the watch to a local Watchrepairman who has worked on watches for over 60 years and together we took the dial off. We can not figure out how to set the time.There is no lever to make it a lever set. Yet, when you pull the stem out it stays in the winding mode.
Is this watch supposed to have a lever and is it just missing or is something wrong with the stem system that prevents it from being put into the time setting mode. The movement doesn't look like it ever had a lever except it does have the grove for one.
If it needs a lever does anyone have one available.
June 05, 2008, 22:26
Chris Abell
A photo with the dial removed would be a great help
www.Abellwatchmakers.com
June 06, 2008, 00:03
Ernie Loga
I thought about that but I don't have the watch in my possession right now so I can't post a photo. I was hoping someone would be familar with the watch who could tell me if it is lever set or pendent set. If it is lever set then I am missing the lever. If it is pendent set then there is something wrong with not being able to set the time.
