January 01, 2017, 14:17
Greg ForresterE Howard & Co series III, model 1862, 15 jewel, size 18 in W. P. & Co. Gold Case
I am looking for information on the collectibility of my model 1862 E. Howard & Co. gold pocket watch with Reeds patent, serial #22010. I am told that it is a size 18, manufactured between 1861-1871, and that it is a series III, 15 jewel watch, in its W. P. & Co case #1043. It is key wound and in perfect working order and aesthetic condition. Unfortunately this site will not allow me to upload photographs due to size limitations. However, I am happy to email photographs it someone has information they are willing to share with me.
I enjoy the watch and carry it often. However, when I last had it serviced by a specialist a collector friend recommended, I was approached by several people interested in buying the piece for amounts I would have thought unheard of prior to reading about some of the items discussed on this forum. Now I am uncomfortable walking around with my watch on a daily basis, and only wear it on special occasions.
If anyone has information about this watch please respond and let me know if it is of interest from a collection perspective, or if I should just enjoy it and pass it down to my nephew. Thank you in advance for your advice.
January 01, 2017, 16:07
Lorne WasylishenIf you want to email the photos I can resize and post them for you. Click on my profile for the email address.
If you have a Mac computer I can tell you how to resize,
Here. If a PC someone else may chime in.
You can also change the image size in your camera settings to VGA which will give proper size images for this forum.
I'm not an expert on early Howards but the Price Guide (
which you can get at a discount if you become an IHC member) shows a list of initials for most of the Solid Gold Watch Case Companies used by E. Howard & C0.
On that list is W P & Co = Wheeler Parsons & Co.
Were it me I would enjoy it and one day pass it on.
January 03, 2017, 12:23
Greg ForresterI think the I finally created a file size in line with requirements. This is the movement of the E Howard & Co series III, 15 jewel, size 18 in the W P & CO 14K gold double hunter case. From the serial number (22010) I believe it to have been manufactured in the mid 1860's.
January 04, 2017, 12:07
Greg ForresterCan anyone tell me if this is what is referred to as a Mershon regulator? Anything else I can learn about this watch will be appreciated.
January 04, 2017, 12:17
Lorne WasylishenLooks like a Mershon to me.
That rigging on the right of your pic that looks like a Maltese cross is called a stop works, I am unable to expand on the explanation below:
The stop-works and the fusee mechanism were both intended to address the problem of isochronism; the stop-works by limiting the mainspring to its "mid-range" i.e. not allowing either a fully-wound or fully-unwound condition, and the fusee by "equalizing" the pull of the mainspring by passing its power through a stepped fusee-barrel which compensated for the unequal pull of the spring.
Image from PWDB
