August 03, 2021, 10:15
Kip Woodringwhy are pocket watch cases refered to as "4oz, 6oz, 8oz" and so on
These terms are confusing, yet common "currency" when discussing pocket watch cases. The "ounce" rating seems disconnected from any actual weight or even dimension. Can anyone explain these seemingly archaic reference terms - so that they make sense?
August 03, 2021, 18:50
Brian C.The ounces are usually for the weight of gold in the case.
August 03, 2021, 22:36
Paul J. WilliamsI believe these would refer mostly only to silver content cases. That number would refer to total alloy weight in Troy ounces. Any accessories such as stem crown crystal springs etc. are not referenced in the quoted number.
August 04, 2021, 10:12
Brian C.Paul, can you post a picture of a silver watch case with it weight marked?
August 04, 2021, 14:52
Paul J. WilliamsThe ones I see are usually coin and early american
August 04, 2021, 14:54
Paul J. Williams3 would generally be accepted as 3 oz
August 04, 2021, 15:15
Paul J. WilliamsSeems to be the 18s are the ones usually marked and even those are limited. When I hear oz's in larger numbers I automatically think silver.
The title mentions 8oz, That sure would be huge, never seen one of those yet.
August 04, 2021, 20:38
Kip WoodringPaul - thanks for the info, it really helped! Is it fair to say, that oz weights only appear (not always) on the cuvette of silver alloyed cases? I've never seen markings on gold-filled or silveroid-type cases. Are 16s cases ever marked? How rare are 5oz and up cases? I only have one 5oz coin case on my Illinois 18s grade 106.
