August 21, 2010, 16:26
Tony DukesWaltham movement, more info please
Need some info on this 16 size waltham movement.
Tony
August 21, 2010, 17:09
Mike LaForestTony,
You mean info like: Model 1908, Grade 635, adjusted,pendant or lever set.
August 21, 2010, 18:28
Cecil McGeeMaybe the year. It was made in 1918
August 21, 2010, 20:16
Hub HarmsStart:   End:
First: 22012501  Last: 22013500
Model: 1908 Name:
Material: A  Grade: No. 635,
Size: 16 Size: 16
Plate: 3/4 Plate:
Jewelling:   Jewels: 17
Balance:   Bal: Pat. Reg. - Breg. HS
Style: OF Style:
 O.F.
Comment: 96
Source:    Date:
August 22, 2010, 00:11
David AbbeNice Carry watch and as an "A" grade would qualify for electric rail transportation use after a clean and adjust.
August 22, 2010, 09:11
Tony DukesThanks guys for the info on the waltham movement. I put the movement in a sturdy case that I got from Phil and as Dave says it makes an excellent carry watch.
Tony
