December 26, 2009, 21:44
Kenneth R. PearsonDo You Think This Clock Needs a Bushing?
This is one of the worst I've seen. It's a New Haven School Clock with no evidence of previous repairs.
December 26, 2009, 23:59
Steve MiddlesworthKen,
Rotate the bushing 180 degrees and it will be fine
Steve
December 27, 2009, 07:52
Eddie G. HinesGREETINGS KENNETH, I WOULD PUT A NEW BUSHING IN AND CHECK THE PIVOT TO SEE IF IT IS WORN IN ANY WAY IT NO DOUBT IS EITHER TAPERED OR IT HAS A STEP IN IT. EDDIE
December 27, 2009, 18:54
Kenneth R. PearsonI was expecting a routine pivot polishing, but the pivot was made about .020" (.5 mm) out of round at the factory, which helped to explain the unusual wear. I turned it true in the lathe before polishing.
