Total hinge replacement project
September 01, 2010, 16:59
Leon HarrisTotal hinge replacement project
This is a Keystone 16 size hunting case that Mary Ann Scott sent me to repair. I have took several pictures of the process of removing the old hinge and replacing it. This first picture is of the case.
September 01, 2010, 17:14
Leon Harristhis picture is of the bad hinge.
September 01, 2010, 17:15
Leon Harrisand another of the bad hinge.
September 01, 2010, 17:17
Leon HarrisThis picture is of the really deep scrapes in the case frame. To make the hinge replacement look good when done. I decided to fill in the deep scrapes.
September 01, 2010, 17:19
Leon Harristhis one shows where I added some metal to fill in the deep scrapes on the case frame. In this picture you can see where the old hinge has been removed. Case is ready for the new hinge.
September 01, 2010, 17:27
Leon HarrisThis one is of the lasered case frame polished and ready for the new hinge
September 01, 2010, 17:28
Leon Harristhis one is the case and front lid with the old hinge gone
September 01, 2010, 17:31
Leon Harristhis one is the new hinge has been cut, and ready to be tacked weld
September 01, 2010, 17:35
Leon Harristhis picture is of the new hinge tacked to see if it will need to be moved or adjusted
September 01, 2010, 17:39
Leon HarrisWith the new hinge all welded up and polished and a new hinge pin installed
September 01, 2010, 17:40
Leon Harrisdifferent angle on the new hinge. It is close to original hinge.
September 01, 2010, 17:42
Leon Harrisfinished case cleaned and lightly polished. What do you think Mary Ann?
If anybody has any questions I will do my best to answer them.
Thanks for your time.
September 01, 2010, 17:48
Steve MiddlesworthBeautiful job Leon......looks like new again.
Steve
September 01, 2010, 18:39
Edward L. Parsons, Jr.That's an amazing transformation Leon, you saved that case from the scrap pile.
September 01, 2010, 19:23
Steven FordVery nice job Leon!
Is the case solid gold or gold filled?
Steve
September 01, 2010, 22:14
Mary Ann ScottLeon - the case turned out wonderful! I am so pleased and can't wait to get it back!
The transformation is incredible. What was once a beat up broken case now looks like it was just made!
It is gold filled, is original to the movement and has a very nice inscription, so I wanted to restore it. I am glad that I did. I highly recommend Leon and the work that he does! Thank you!
September 02, 2010, 07:43
Phillip SanchezLeon, You are the Master. I still want to go over there and be your apprentice.
September 02, 2010, 07:51
Edward KitnerIncredible job Leon, you are indeed a master!
September 02, 2010, 15:07
Keith KlimkowiczWOW nice job...
September 05, 2010, 07:53
Vincent Pullara, Jr.5 stars to Leon. Not only for his excellent craftsmanship, but taking the time to share his expertise with us. Thank you Leon.
September 05, 2010, 11:42
Robert V. JonesGreat job Leon as you have done for me in the past. That is why I highly reccomend you to anyone who asks me. Thanks for sharing the step by step pictures.
November 20, 2010, 19:46
Peter L. BelmonteLeon,
That's a beautiful job. Did you grind the old hinge away, or did you use a sep disk, or ??? Those laser welders are nice, that's for sure.
Thanks for showing this project. I'd like to see more of your case work.
Pete Belmonte
November 22, 2010, 15:28
Leon HarrisHi Peter, I have 30 years as a jewelery repairman. So yes I did grind the old hinge away, and yes I did use a sepereting disc in a hand piece. I have reworked a Hamilton model 2 case that I need to get the pictures on the 185.
November 23, 2010, 08:53
I'd love to see the pictures for the Hamilton model 2 case. I used to work on watches, but a few years ago I decided to concentrate on making jewelry (although I still "dabble" in various watch areas), so I like to see this kind of work. I worked part-time as a bench jeweler and I got to assist the jeweler in a similar case repair -- it was a lot of fun to see how it shaped up. Thanks again,
Pete
November 23, 2010, 10:20
Ernie LogaGreat job, Leon! Some people have talent but Leon has more than that. He indeed is a master!
