September 25, 2009, 15:31
Steve Gossardsizing digital pictures
I just got a new Nikon DX 5000 (and close-up lenses) that takes great pictures, but the images are as big as a movie screen. Every time I try to resize the images I wind up with nothing left but the upper left hand corner. How the heck do I reduce the size?
Steve Gossard
September 26, 2009, 13:38
Hi Steve,
Multi-mega-pixels in newer cameras such as the 12.3 Megapixels in your Nikon DX 5000 does a lot to improve picture quality, but as you pointed out we do not always need gigantic poster sized or wall mural images. When it comes to sharing through eMails or posting on the Internet the pixels need to be cut way, way down. Software to accomplish this likely came with your camera. You can also change settings on the camera, but since the aforementioned software allows more flexibility that is usually the way to go.
You described ending up with only a corner of the image so that makes me think you are using imaging software but perhaps you just need to figure it out completely. My impression is you are cropping the image which is the term for cutting out unwanted areas rather than actually reducing the overall size. If you are using Nikon software my suggestion would be to call 1-800-645-6689 as described here...
CLICK FOR: Nikon Technical and Service Support
When I download images from my Nikon they first go into iPhoto where I select the ones I want to save. Then, one by one I process them in "Photoshop Elements" (See HELP IN POSTING IMAGES for other software suggestions) in order to balance brightness, contrast and such. That could essentially be done in either of those programs and so could changing the size of the image, usually 640 X 480 is good for Internet use, as well as cutting the resolution to less than 100 Kbps which is also important for posting here on IHC185 as well as eMail sharing and the like.
This is complicated at first but it becomes easier with practice.
Hope this helps,
September 27, 2009, 07:50
Steve GossardThanks Lindell. I'll keep working with it.
Steve
February 14, 2013, 06:20
Donald C. HendersonUse IrfanView, it will automatically display the images sized for your screen and then you can easily crop and resize them however you want. I also just use the importing feature built into Windows to get the images from the camera and then open, edit, and resave them with IrfanView.
Sorry I didn't realize this was such an old thread.
February 14, 2013, 09:00
Dave TurnerDonald,
I use IrfanView also. But I still haven't figured out how to make a collage.
February 14, 2013, 10:17
Donald C. HendersonThat's easy Dave. You choose to create a new panorama image. Then you add the pictures you want, reorder them how you like, choose horizontal or vertical orientation, and click on create image.
February 14, 2013, 13:28
Dave TurnerDonald, That all sounds familiar. I'll play with it again.
