Rust removal by electrolysis "Click" to Login or Register
I just tried using electrolysis to remove some rust on a winding crown for a 1908 Waltham watch. It worked like the proverbial magic charm. I haven't yet tried it with any clock parts, but we all know how the lantern pinons in American clocks frequently seem to be rusted inside the lantern. I am going to try this with a junk part, to see if it will work to clean up the trunions without hurting the brass hubs or attached wheels.
For the watch parts, I used 2 "D" cells for power, and a chunk of scrap iron as the sacrificial anode.
When I made the electrolyte solution, I didn't measure: I just dumped what looked like about a tablespoon of Washing Soda into a gallon of water, and shook it up. As the guy says in the attached file, "This ain't rocket science."
My container is a plastic pint ice cream container.
I just attached clip leads to one end of two pieces of wire, and taped the other end of the wires to the positive and negative poles of a pair of "D" cells that I taped together end to end to give about 3 VDC. I was pretty careful not to touch the two leads to each other, since there is no "Off" switch. :-) I used wooden spring clothespins to hold each lead against the inside of the container. OF course, for bigger stuff, you'd' probably want a gallon container, and maybe more power, and heavier clips to hold the stuff in the container so they can't touch, but the principle is the same.
Here's a pdf file of the best article I found.
IHC Member 1902
David this looks a very good solution which I'm sure will be extremely useful in saving watch parts.
I've saved the article for future reference.
Thanks for posting
Mike
Posts: 575 | Location: Walsall in the United Kingdom | Registered: December 19, 2013
IHC Member 1541
Picture of Lorne Wasylishen
Very interesting David, great find and thank you for posting.
