Page 1 2
South Bend Dial Database, Pictures! "Click" to Login or Register
South-Bend Expert
Picture of Frank Kusumoto
Inspired by the thread of movement pictures, Keith Klimkowicz has made the excellent suggestion to make a similar thread devoted to dials. Surely an excellent suggestion. In my years of collecting I've been attempting to create a system for identifying dials and have come up with one that works well for me. It works this way:
1st position is E or M. E for Enamel, M for Metal.
2nd position is SS or DS, for Single Sunk or Double Sunk, which only applies to enamel dials.
3rd position is "Arabic" or "Roman" for the number system used.
This little nomenclature helps me to quickly add a note about a dial. So if I have
"E, DS, Roman" Then I know it was a enamel double sunk dial with roman numerals.
I also use one last type of designation in the 4th position. I use the catalog pages that have dials shown. Almost all of them include model numbers or stock numbers. Thus when I have this dial I know that it is in the 1914 catalog on page 46, and it is model 211. So this dial I would annotate:
E, SS, Arabic, 14-46-211
Posts: 1045 | Location: Denver, Colorado U.S.A. | Registered: October 08, 2004
South-Bend Expert
A slightly better picture of the first dial, from a 18s 305:
South-Bend Expert
Here's a comparison of two dials. The one on the left is appropriate for a 295 or a Polaris and was produced around 1909. The dial on the right is the replacement dial that South Bend started making in the 1912-1914 time period. They changed over the font slightly and changed the text so that it leaned to the right instead of the left.
South-Bend Expert
This dial appeared in the 1917 catalog on page 69 and is designated as number 397 (DS version). Therefore I refer to it as "E,DS,Arabic,17-69-397".
South-Bend Expert
This dial is one of my favourites (and I'm probably not in the minority there). It is first seen in the 1914 catalog on page 46, and is listed as item 314. Thus for this dial I list it as "E,DS,Arabic,Monty,14-46-314".
This dial is the correct dial for most 227's and a likely dial for a 223 or 229. This style of dial with the script signature (as opposed to the block signature) is probably not appropriate for a 219 (which would use the block signature type Montgomery).
IHC Member 48
Picture of Keith Klimkowicz
This is a not so common dial on a grade 227.
Posts: 842 | Location: North Ridgeville, Ohio USA | Registered: November 19, 2002
Site Moderator
Picture of John J. Flahive III
Here is one that I found in an antique store in BC. It was on a Grade 229, "The Studebaker".
Posts: 1750 | Location: Wisconsin in the USA | Registered: October 17, 2005
South-Bend Expert
John - that's amazing. I thought that dial only existed in catalogs.
South-Bend Expert
Here's a 12s dial. It was one of the premier dials and the most expensive dial to add to a 12s watch in the 1925 catalog at the cost of $10. The raised gold numerals were apparently a desirable and expensive feature. This dial has been redone. All of the dials of this style usually have issues because the metal dials and the paint used on the original dials just doesn't seem to hold up well after 80 years. In my experience if you have a dial of this style redone this is about as good as you can expect it to turn out.
South-Bend Expert
Another 12s dial. This dial has also been redone. It was in such bad shape I almost round-filed it but decided to let the redialers have a go at it since it is one of the more rare dials. I'm quite happy with the results.
Here, the original topic about John's remarkable dial.
CLICK FOR: "Canadian South Bend Dial" by John Flahive
Below, perhaps the only 18-size survivor of this design...
Posts: 10516 | Location: Northeastern Ohio in the USA | Registered: November 19, 2002
Wristwatch Host
Picture of Tony Dukes
Frank,
Could you post some pics of the back side of a 12 size,16 size, and 18 size South Bend Dial. Any info about the dial feet would be helpful. Thanks/////
Tony
Posts: 1943 | Location: Atlanta, Georgia in the U.S.A. | Registered: August 01, 2003
Picture of Ernie Loga
Here is the dial on one of my SB 280 watches serial number 506894. I am not sure if it is correct for the watch. I think the slant of the script is wrong for the year of the watch. The movement had been recased into an open face before I aquired it.
Posts: 910 | Location: Wisconsin in the U.S.A. | Registered: April 28, 2008
IHC Member 1153
What great dials.
Frank you show a 12s dial here posted April 11/08 at 12:00.that you state is quite rare,and this is why you had a redialer redo it, is there not many watches with this dial? I have one on a 12s with a 429 mvmt. I have just recently started collecting and would love to think I have a hard to get item.
Thanks for any info ,
Bill
Posts: 1261 | Location: British Columbia in Canada | Registered: May 19, 2008
South-Bend Expert
This dial appears to be original but I can't find an example of it in the literature. The Gothic numerals and the engraved center were both widely used starting in 1924.
South-Bend Expert
Perhaps the most widely associated dial style of the Studebaker Mail-Order watches after the Montgomery style. This dial is shown in the 1924 Studebaker style guide on page 9, and is identified as dial No.154. I refer to it as the "S24-9-154". The style was also available for the South Bend watches and was available for both brands at various times in Green Gold, Gold and Silver.
Here is the dial on 294 #469414
Posts: 769 | Location: Los Osos, California USA | Registered: December 12, 2002
Site Moderator
Picture of Tom Brown
Well I got my 1st South Bend today, it is a 227 with a pretty worn metal dial but I thought I would add the dial photo here. I paid $35 for the watch, which runs, so I guess even though the dial is worn I didn't do too bad.
227 Dial
Posts: 5113 | Location: New Mexico in the USA | Registered: January 27, 2007
Here is the dial on a grade 227 from 1912 Run 4
Here a 315 Dial from 1919.
Picture of Jerry King
Here is a South Bend that I purchased recently. It is a mdl. 219 and has damage to the dial at about 17 min. & 38 min. mark as you can see.
Can this type damage be repaired or will it be necesary to replace the dial.
Posts: 2860 | Location: Chino, California in the USA | Registered: June 23, 2008
Here the dial from my South Bend Size 6 grade 180.
South-Bend Expert
This one is a little odd 12s dial. It is two-tone in Gold/Silver with the raised relief motif. I've seen similar ones marked by South Bend but this is the only one marked Studebaker that I've seen.
Site Moderator
Here is a double sunk version of the first one you posted. It came on my Grade 295.
IHC Member 48
A very uncommon dial on a 18s 304. Hunter converted to open face without the seconds bit.
South-Bend Expert
Keith, it that an enamel dial? The 304 is one of the hardest watches to find. It would be interesting to figure out what dial was made for it by South Bend since it would have to be pretty much a "custom" dial.
IHC Member 48
Frank
Thanks for the kind words, but if you use the find or search area and type in 304 you will find this has been discussed before.
Yes this is a enamel dial.
IHC Member 1153
Hi all,
Here is a 12s Studebaker dial, can we do anything with it, or can a refinisher do a good job on it. It is a gold colored metal dial ?
Bill
Picture of Ethan Lipsig
Refinishers can do nice jobs. Here is a before refinishing shot of the dial on my South Bend 431.
Posts: 1344 | Location: Pasadena, California USA | Registered: November 11, 2005
Here is how it looked after being refinished. Not perfect, perhaps, but better than what I started with.
South-Bend Expert
Bill - I have a similar dial that was in as bad or worse shape as yours. I sent it to Eagle Dial Company and this is what I got back:
IHC Member 1153
Frank,
Great Job on the dial, where are they located.
Bill
South-Bend Expert
Eagle Dial Refinishing Co.
132 S. 8th St. (2nd Floor)
Philadelphia, PA 19107
(215) 925-7423
I am not affiliated with them in any way except for being their customer for the last four years. They do a very good job on the work I send them and they have very competitive prices. I do think they are the best company for the price for PW dials, although your mileage may vary.
©2002-2018 Internet Horology Club 185™ - Lindell V. Riddle President - All Rights Reserved Worldwide
