movement is running fine, just need some love and good clean. Now about dial, I know that fancy dial should fit nicely, but what else? Does any one have spare dial which would be correct for this grade? Appreciate any advise on that.
Rafal
Posts: 266 | Location: Wroclaw in Poland | Registered: May 06, 2013
Thanks Bila, I thought no one is reading this forum anymore . I was wondering what would be "standard" dial in this case, like fancy script or Montgomery for 229.
Roger is right about the fancy script and Lorne's dial in his link is the perfect match for it. The South Bend literature does say they came with the fancy dial as well, as Roger has alluded to.
I think you find though if you dig a bit deeper, most that have been seen carry the double sunk, roman numeral dial with South Bend in fancy script.
Posts: 2262 | Location: Gladstone in Australia | Registered: January 14, 2011
Many thanks Bila, Roger and Lorne for your help. I was doing my own little research but there is so little info and only a few pieces of this grade available online to see dials... and I decided to start this thread. Cheers.
