Detent stem: Waltham Royal Model 1888 "Click" to Login or Register
IHC Member 1357
Detent stem on a Waltham Royal Model 1888. The stem does not pull up to set time nor by loosing the detent screw
the stem will not pull out of movement. How far can
I loosen the screw. Sure would like to get movement
out of case. Any advice appreciated.
Roger
Posts: 4093 | Location: Carbon, Texas in the USA | Registered: January 24, 2010
Roger,
The stem release screw needs to turn counter clockwise until it stops. Even then, sometimes time takes some wiggling to get the locking pawl to let go, old grease and dirt stick it in place. Sometimes releasing the movement screw helps, too. That may also be why it will not set. Cleaning and new oil usually fix both problems.
Hope this helps.
Steve
Posts: 692 | Location: Washington in the USA | Registered: May 23, 2010
Certified Watchmaker
Picture of Chris Abell
Easy way is just to take the barrel bridge off while inside the case and see what's going on.
Thanks Chris,
You pros know all the easy ways to do things!
Steve
IHC Member 1357
Thank you guys. Got it done
Roger
