992B Nomenclature "Click" to Login or Register
IHC Member 2256
Please pardon my naïveté...
I understand that the 992”L” nomenclature indicates “Lever set”, that 992”E” indicates “Elinvar” ... What does the “B” indicate? Is it a design sequence? If so, was there a 992”A”? What differentiated “A” from “B”?
Are there other 992 suffixes?
Thanks
Gropo
Posts: 27 | Location: Illinois and Maine in the USA | Registered: May 01, 2018
IHC Member 1517
Steve
To answer your questions in order, the "B" represents a significant redesign of the 992 model which came out in 1940 and to quote Hamilton's description "This is a completely new movement from winding arbor to balance wheel, and its parts are not interchangeable with those of previous 992's". However, with the exception of the hairspring, all parts can be interchanged with other 992B's without affecting the function of the watch. Some of the changes included friction fit jewels, an improved Elinvar hairspring, a 2 piece press-fit balance staff, and an improved winding and setting mechanism.
There was not a 992A model. The only other suffix would be the 992P signifying the pendant set version which came out around 1912. The "L" & "P" are not model designations, just configuration descriptors.
Posts: 355 | Location: Woodland Hills, California in the USA | Registered: January 07, 2011
Robert is exactly right, the Hamilton "B" Series of watches were the first truly interchangeable movements. You will find there is only one numbered part, the pillar plate. Because of the precision with which these were designed, there was no special fitting of parts required.
They are simple to service, extremely reliable and excellent timekeepers. In many ways despite their somewhat plain-look compared to earlier models the Hamilton "B" series of movements are from an intended-use performance standpoint among the finest pocket watches ever produced. And every last one was designed, engineered and assembled in Lancaster, Pennsylvania - United States of America.
The factory complex still stands, converted to upscale condominiums.
Posts: 10522 | Location: Northeastern Ohio in the USA | Registered: November 19, 2002
©2002-2019 Internet Horology Club 185™ - Lindell V. Riddle President - All Rights Reserved Worldwide
