Greetings all. I haven't pestered you for a while, so I thought it was about time! I recently won a Keystone Howard and had a couple of questions. I'm really just trying to figure out what it is. Serial number is 1203089. 17 jewels. It says Pat'd 12 instead of Pat'd 18 which I've seen on a close number online (though to be honest, I'm not sure the significance of either). Am I correct that it is a Series 7? 1915 ish? It's my first Howard and I just looking for anything you guys know. Thanks and here are a few pics.
Posts: 257 | Location: Worthington, Ohio in the USA | Registered: December 20, 2005
Edward - Yes. Your watch is classified as a Series 7, featuring 17 jewels, and adjusted to temperature, isochronism, and three positions. The updated patent marking indicates improvements in the setting mechanism. Attached images are from a c.1909 Howard Watches catalog describing the Series 7. (Notice your watch is not fitted with the stop-work mechanism)
What I thought, picked up a 12s 19s missing either the stem and crown or just the crown but I tend to think it is both crown and stem. I noticed the small screw to set the detent so one lesson learned on Howards.
Posts: 1797 | Location: Michigan in the USA | Registered: September 19, 2009
Just about those regulator whip springs Edward, be aware that there is a difference between 12 size Howard whip springs not all will interchange.
This seems to be a weak spot with these models, as a great deal of them you will come across have broken whip springs in my experience. Yours might have been pilfered for another watch
Posts: 2265 | Location: Gladstone in Australia | Registered: January 14, 2011
